eTrex Legend HCx/Vista HCx (for WebUpdater) software version 3.20
eTrex Legend HCx/Vista HCx (for WebUpdater) software version 3.20 du 3 décembre :
Changes made from version 3.10 to 3.20:
* Fix shutdown issue when press menu key at first power on with 100% backlight setting.
* Fix minutes to hours roll over issue.
Changes made from version 3.00 to 3.10:
* Fix potential lock up when SD card installed.
* Fix the contour data intermittently drawing over interstates of Topo Map.
* Improve the blue shading color when using the setting 'Marine colors' in Daytime display mode.
* Correct the brightness can't move over 50% in eTrex Vista HCx.
* Correct upside down direction of vertical speed.
* Fix incorrect highlight index at unit field in 'Area Calculation' page after select reset in menu.
» eTrex Legend/Vista H software version 2.80 du 06/03/2019
» eTrex Legend Cx/Vista Cx/Venture Cx (region file only) software version 3.50 du 07/08/2019
» eTrex 20/30 (Webupdater) software version 2.40
» eTrex 20/30 (Webupdater) software version 4.90 du 19/02/2019
» eTrex 20x/30x (Webupdater) software version 3.00 du 19/02/2019
