[Résolu] Carte Bluechart sous Basecamp
[Résolu] Carte Bluechart sous Basecamp Empty [Résolu] Carte Bluechart sous Basecamp
Message par Invité Mer 10 Nov 2010 - 19:22
j'ai installé basecamp à l'instant.
J'avais 2 cartes sous MapSource d'installée :
- Blue chart America (carte Marine des caraibes)
- Topo 11 outre mer (carte terrestre Martinique)
Sous Base camp je ne retrouve que :
Comment faire pour réimporter ma carte Blue Chart ?
Encore merci à vous :p
[Résolu] Carte Bluechart sous Basecamp Empty Re: [Résolu] Carte Bluechart sous Basecamp
Message par Invité Mer 10 Nov 2010 - 19:26
Ok je me répond à moi même ça pourra être utile pour les autres
En résumé : C'est mort
BaseCamp software version 3.1.1 - Patched
as of October 19, 2010
Notes:
Windows XP Service Pack 3 or later is required.
.NET framework 3.5 is required. A current version of .NET will be installed if needed.
1 GB of system memory is required, 2 GB of system memory is recommended when using BirdsEye Imagery or Garmin Custom Maps.
A video card that supports OpenGL version 1.3 or later is needed to enable the 3D view.
If you experience problems when interacting with the map views, please make sure that you have installed current video card drivers.
BaseCamp will recognize all MapSource products except BlueChart.
BaseCamp does not work with serial GPS devices.
Changes made from version 3.0.6 to 3.1.1:
Added support for multiple new BirdsEye products.
Added support for sorting, searching, browsing and filtering user data.
Added support for ejecting devices from within BaseCamp.
Added support for filtering tracks.
Added support for display of track statistics and temperature.
Added support for time offsets while geotagging photos from tracks.
Added support for editing multiple waypoints, routes and tracks at a time.
Added support for importing geotagged photos.
Added support for full screen mode.
Added support for non-rectangular selection area for BirdsEye downloads.
Improved performance while importing, geotagging, autosaving and routing.
Improved support for various DPI settings.
Reduced memory required by BirdsEye imagery.
