Firmware V3.0 pour 62/78
Firmware V3.0:
* Updated magnetic Earth field data
* Improved GPS performance
* Improved support for BirdsEye™ Satellite Imagery (each provider's imagery can be configured independently)
* Increased the maximum number of supported JNX files to 250 from 200
* Fixed issues with WAAS/EGNOS
* Fixed issue with track navigation sometimes not adding waypoints to the Active Route list
* Fixed issue with track and route review from the map page if you came from the elevation plot
* Fixed issue with MPC map labels disappearing
* Fixed issue with gpi files that have alerts attached to the points
* Fixed issue with progress bar displaying properly on power up
* Fixed issue with track navigation not adding waypoints to the Active Route list when they are exactly equal to a track point
* Fixed shutdown when unit had more than the maximum number of JNX files on it
* Fixed shutdown related to topographical maps and land cover text size
* Fixed Glide Ratio to Destination field
* Fixed problem with profiles and the fields on the map page
* Fixed an issue with magnetic north reference and waypoint headings
* Fixed shutdown on the map screen when a waypoint was being moved to the same location as a geocache or other POIs
* Fixed issue where proximity waypoint alerts could only be set in feet regardless of what was selected as a Distance/Speed unit in the setup page
* Fixed an issue with archived tracks not displaying properly
* Fixed an issue with having too many custom symbols on the device
* Modified the 'Arriving at Destination' message banner so that it no longer appears when navigating to a geocache
Pour ceux qui comme moi préfèrent se passer du webupdater on peut le télécharger ICI. Lien direct vers le fichier : [Vous devez être inscrit et connecté pour voir ce lien]
Francis
Francis
Cytochrome- 5 sat
Re: Firmware V3.0 pour 62/78
Version non Beta depuis la 2.8, c'est important, règle déjà pas mal de problèmes rencontrés. Manque encore le raz odomètre total... Précision des traces équivalentes au 60csx même sur affichage!
