transférer carte topo d'un Oregon 600 vers Basecamp
Page 2 sur 2 Précédent  1, 2
transférer carte topo d'un Oregon 600 vers Basecamp - Page 2 Empty Re: transférer carte topo d'un Oregon 600 vers Basecamp
Message par BBoris50 Mar 11 Mar 2014 - 23:09
Ok mais la carte France n'est pas similaire à la carte de la Bulgarie  Very Happy
BBoris50
Message par BBoris50 Mer 12 Mar 2014 - 20:20
Pas besoin de chercher plus loin; j'ai la réponse après avoir consulté le "producteur" de la carte bulgare ! Voici sa réponse:
When you connect your Garmin Oregon 600 to your computer and launch BaseCamp, the program should be able to read and display the installed maps on your GPS device to allow you to plan routes, transfer POIs, etc, but only as long as the GPS device is connected to the computer. Once you disconnect the device, its maps are no longer accessible through BaseCamp, because BaseCamp reads the maps directly from the GPS device without installing them on the computer.
If you prefer to have permanently installed OFRM Geotrade map on your computer, we offer additional support for PC (installation bundle of OFRM Geotrade with MapSource) as a sublicence to your OFRM Geotrade map licence with two-year subscription for updates for 59,98 BGN. Please keep in mind that the sublicence subscription for updates is only accessible if the main licence subscription for updates is active (not expired). To purchase support for PC, please visit our website [Vous devez être inscrit et connecté pour voir ce lien]   and log into your personal profile. Upon successful login, the website will display the "Support" page. Under section "My Licences" click on the "UPGRADE - Support for PC" button and follow the provided instructions to purchase the additional support for PC. Once purchased and installed, OFRM Geotrade map can be used on your computer either with MapSource or with BaseCamp, accorging to your personal preference
Bref pour moi c'est une arnaque à la sauce bulgare ! qu'en pensez vous ?
BBoris50
Message par Monique Jeu 13 Mar 2014 - 21:09
On a déjà évoqué sur le forum les choix proposés par Garmin pour l'achat de certaines cartes comme les City Navigator (microSD, téléchargement, DVD), tous les 3 au même prix mais pas avec les mêmes avantages, sans que cela soit bien évident sur leur site. En effet, seul le DVD permet l'installation de la cartographie sur l'ordinateur sans avoir recours à des astuces comme le disque virtuel.
"Arnaque à la sauce bulgare" ou pas, la copie des 3 fichiers ".img", ".unl" et ".gma" de ta microSD sur le disque virtuel devrait suffire à afficher la carte de la Bulgarie dans BaseCamp mais, attention, il faut être patient, elle mettra pas mal de temps à se charger. C'est le cas avec les fichiers de ma microSD Topo France v3-Pro copiés sur le disque virtuel de mon PC, BaseCamp affiche bien la carte correspondante mais au bout de plusieurs minutes... Ce qui me fait penser que tu n'as peut-être pas attendu suffisamment.
