Forcer le mode Storage USB sur les Oregon 6xx et 7x0
Pour les Oregon 6xx et 7x0, voir cette méthode :
Pour les Oregon 6xx, GPSrChive a écrit:
If your Oregon 6xx is freezing or crashing during startup, it is likely a recently added map, image, gpx or other file that is creating the issue.
Forced USB Mass Storage Mode
The following procedure forces your Oregon 6xx into USB Mass Storage Mode so that you can delete/remove/rename any recently added files:
- Remove battery and µSD card from your Oregon 6xx
- Connect the Oregon 6xx to your computer with a USB cable
- As the Oregon 6xx powers up and begins the boot process, immediately press and hold the power button without disconnecting the USB cable until the Oregon 6xx powers down
- Press and Hold the power button for 30 seconds, or until the USB symbol appears on the Oregon 6xx display
- The Oregon 6xx will be in USB Mass Storage Mode
- Remove or rename any recently added maps, images, gpx or other files that may be causing the issue
- Disconnect the Oregon 6xx from the USB cable
- Install previously removed battery / µSD card and power up the Oregon 6xx
- Repeat Steps 1-8 as needed until the Oregon 6xx boots properly
» Recovery pour le Montana : forcer le mode USB Mass Storage, forcer l'installation du firmware RGN
» Oregon 600 non détecté sur ordinateur
» Plantage oregon 700 et impossibilité de passer le GPS en mode USB Mass Storage... !!
» Forcer l'installation d'un firmware en RGN sur les Oregon 6xx et 7x0
» Recherche en mode vol d'oiseau sur Oregon 700 ?
