MAJ BaseCamp Mac
MAJ BaseCamp Mac Empty MAJ BaseCamp Mac
Message par Invité Mar 13 Avr 2010 - 8:22
Bonjour amis du Macintosh !
(je poste ici, merci de déplacer si un autre emplacement est plus approprié)
BC est dispo en version 3.0.1, anglais seulement pour le moment
Changes made from version 2.0.1 to 3.0.1:
  • Added download, display, and transfer of BirdsEye satellite
    imagery. This requires that you have a supported Garmin GPS. See here for more
    information.
  • Added download, display and transfer Garmin Custom Maps to
    supported devices.
  • Added the ability to use pre-installed maps on a connected device
    or pre-programmed SD card.
  • Added ability for BaseCamp to display any Garmin map. Maps do not
    need to have Digital Elevation Model (DEM) data to be displayed in
    BaseCamp now.
  • Added support for the data sync capability in the Oregon 450 and
    550 and Dakota 10 and 20.
  • Added ability to drag and drop user data to and from connected
    devices.
  • Added ability to edit multiple waypoints.
  • Fixed issue with garbage characters that were displayed in pop‐up
    labels in Snow Leopard (10.6).
  • Added printing of USGS Quads and other public land survey areas.
  • Added ability to reset preferences to factory defaults.
  • The full information for geocaches is now visible when transferred
    to devices that have enhanced support for geocaching, including hints,
    terrain, difficulty and logs.
  • Improved handling of back-up database.
  • Improved the drawing speed of certain European maps.
  • Improved the reading speed and display of Geotagged photos.
  • Adjust map drawing colors to better distinguish between major
    highways and interstates.
  • Added support for touchpad multi-touch gestures.
  • Added to print on several pages.
  • Fixed issue where information about found POI or address was not
    displayed correctly in Snow Leopard.
  • Fixed an issue where selecting a waypoint symbol in the Waypoint
    Dialog could cause a crash.
  • Numerous refinements and problem fixes.
  • Added numerous other refinements and problem fixes.
MAJ BaseCamp Mac Empty Re: MAJ BaseCamp Mac
Message par Invité Mar 13 Avr 2010 - 12:10
Merci pour l'info. Smile
Message par chocapic Dim 18 Avr 2010 - 15:54
A propos de Base Camp, (j'utilise un etrex vista hcx pour des randonnées vtt), savez-vous si il existe un moyen d'avoir le dénivelé total effectué sur une sortie?
Le profil d'altitude ne le donne pas, alors faut il se le calculer à la main?
chocapic
Message par Invité Dim 18 Avr 2010 - 19:32
chocapic a écrit:A propos de Base Camp, (j'utilise un etrex vista hcx pour des randonnées vtt), savez-vous si il existe un moyen d'avoir le dénivelé total effectué sur une sortie?
Non, pas de calcul de D+/D- dans BaseCamp malheureusement...
J'utilise à l'occasion ce site qui propose le calcul après un upload de ton .gpx : [Vous devez être inscrit et connecté pour voir ce lien]
