BaseCamp software versions 3.0.5 (PC) et 3.0.2 (MAC) en français pour utiliser les cartes du GPS sans qu'elles soient installées
BaseCamp software version 3.0.5 du 10 juin (je sais, je suis en retard
) pour PC à télécharger ici :
Pour MAC, c'est la version 3.0.2 du 14 juin là :
Changes made from version 3.0.4 to 3.0.5 : (version PC)
* Added localization for the following languages: Chinese (Traditional), Croatian, Czech, Danish, Dutch, Finnish, French, German, Hungarian, Italian, Japanese, Norwegian (Bokmal), Polish, Russian, Slovak, Slovenian, Spanish, Swedish
* Added the ability to unlock BirdsEye Imagery for a specific device.
* Added support to recognize European Topographic cards as retail products.
* Improved map projection when printing BirdsEye Imagery.
* Change to preserve subfolders when writing Garmin Custom Maps.
* Change to correctly resolve relative paths in links on waypoints received from devices.
* Change to use a more reasonable zoom level when selecting 'Show on map' for a single find result or waypoint.
* Change to update the database to reflect missing images when doing a 'Restore' when the images were excluded from the backed up.
* Change to preserve selection of device when starting BirdsEye wizard, if a device was previously selected.
* Change to read maps on SD cards written to the \Map subfolder.
* Fixed auto-routing issues on certain maps.
* Fixed copy/paste of geotagged photos from a device not copying the photo.
* Fixed possible issues when launching an external file or URL link.
* Fixed issues when reading geotagged photos with invalid timestamps.
* Fixed displaying postal code twice in POI property balloons in some European maps.
* Fixed issues geotagging photos with Asian language paths.
Attention, lire les Notes en haut de la page avant de télécharger.
Les versions précédentes permettaient déjà d'utiliser la cartographie du GPS connecté à l'ordinateur (ou de la SD ou microSD qui s'y trouvait) sans qu'elle soit installée sur l'ordinateur mais elles étaient en anglais. Ces versions 3.0.5 sur PC et 3.0.2 sur MAC sont installables en français.
![Embarassed](https://2img.net/i/fa/i/smiles/icon_redface.gif)
Re: BaseCamp software versions 3.0.5 (PC) et 3.0.2 (MAC) en français pour utiliser les cartes du GPS sans qu'elles soient installées
A priori, Basecamp va prendre la relève de Mapsource
![Question](https://2img.net/i/fa/i/smiles/icon_question.gif)
t-teuf- 3 sat
C'est ce que je crains. J'espère me tromper car je préfère MapSource.
Moi également je préfère Mapsource, mais je tiens cette info d'une source que je pense fiable
![Crying or Very sad](https://2img.net/i/fa/i/smiles/icon_cry.gif)
t-teuf- 3 sat
Concrètement pourquoi préférez vous MapSource?
DAIG- 3 sat
- Moins lourd (cad peut tourner sur un PC pas trop musclé)
- les vieilles version jusqu'à 6.13.7 acceptent les cartes "non commerciales" sans pb
- moins de pb de déverrouillage de cartes
bonjour, ou trouver les màj des cartes car j'ai une vielle carte la sur le Basecamp et très peu détaillée
nowacop- 1 sat
Si tu fais la mise à jour de la carte de ton GPS, celle de BaseCamp doit être faite par la même occasion … (via l'install sur l'ordi).
» deux versions de cartes installées ?
» Comment Transférer des cartes installées dans BaseCamp vers le GPS62S
» Tuto "Route sinueuse" : utilisation de l'option dans Basecamp, sans l'utiliser sur le GPS
» Quelles cartes pour un GPS Etrex 30
» itinéraire bizarre si versions de cartes différentes sur Nav 6 et BaseCamp
