Edge 1050 version 10.19
Edge 1050 version 10.19 Empty Edge 1050 version 10.19
Message par Monique Lun 16 Sep 2024 - 9:09
Edge 1050 séries software version : [Vous devez être inscrit et connecté pour voir ce lien]
Change History :
Changes made from version 10.18 to 10.19 (19/09/2024):
Fixed memory leak issue that could cause a crash
Changes made from version 9.11 to 10.18 (09/09/2024):
Added Garmin Share. Share your workouts, courses, and waypoints between compatible Garmin devices.
Added ecosystem-wide Garmin Coach support. Train for an event, achieve a milestone, or improve your fitness with dynamic Garmin Coach training plans for runners and cyclists.
Added GroupRide awards and climb competitions.
Added road hazards support. Get alerts for road hazards reported by fellow cyclists and contribute your own edits.
Added wind and stamina adjustments to Power Guide.
Added surface type support including on the map, in-ride unpaved road alerts, and post-ride summary.
Added Wi-Fi map download support.
Added revamped Course Creator.
Updated grade algorithm to be much more responsive.
ClimbPro
Fixed climb clusters failing to display climb details.
Fixed an issue where the climb list page could highlight the incorrect current climb.
Fixed climbs drawing on a course when ClimbPro is disabled.
Retained the setting for the ClimbPro, Segment, and PowerGuide slider between page uses.
Added support for India basemap.
Added gear presets for SRAM 12 speed cassettes.
Added a QR code to quickly pair a Strava account with Garmin Connect.
Added search alias support to improve location searching.
Added course search to the search bar.
Fixed USB connection detection when coming out of suspend mode.
Fixed crash that could occur when saving the ride.
Fixed incident detection countdown timeout notification priority over any other notifications.
Fixed infinite elevation calibration prompt following a manual calibration.
Removed tone from elevation calibration prompt.
Fixed mute toggle interactions on the notifications widget.
Fixed pausing navigation.
Improved speed of city search.
Improved phonetic and hand-writing keyboard input.
Fixed ride button failing to show after receiving and reviewing a Connected POI.
Fixed friendly name for phone pairing.
Fixed issue where hazards in China could appear offset on the map.
Set minimum backlight level to retain screen visibility after backlight timeout expires.
Persisted backlight level setting through battery saver enable and disable.
Fixed battery remaining time estimate not updating when toggling Hide Map option in battery saver menu.
Fixed display of battery level when it dropped below 5%.
Fixed small roads on map being drawn too thick.
Fixed behavior of menus from popping back to previous page to remaining on page after data entry.
Fixed an issue where British coordinates could not fully be entered with the keyboard.
Improved layout of post-ride highlights page.
Fixed various crashes and freezes.
Changes made from version 9.09 to 9.11:
Improved performance of hazards including fixing an issue where a hazard would not prompt.
Fixed an issue where Power Guide target could display incorrectly after a climb.
Changes made in version 9.09:
Added Garmin Share.
Updated GNSS firmware to 11.00
GroupRide Improvements:
Added descriptions and fixed values for GroupRide awards.
Fixed issue where GroupRide shared code is lost if consent is required.
Removed redundant time information in competition results.
Fixed GroupRide course not downloading and failing to display after a ride.
Fixed layout of awards list items.
Fixed awards taking a long time to show up in history.
Fixed errant climb competition winner when climb doesn't register as a competition.
Fixed showing start distances for competitions.
Fixed issue where a hazard would still be visible after a downvote on a ride.
Added a QR code to quick link to pair a Strava account with Garmin Connect.
Integrated CIQ glance theme support.
Fixed crash that could occur when updating Power Guide.
Fixed crash that could occur when navigating back to start.
Fixed crash that could occur when using course creator.
Fixed freeze that could occur during WiFi sync.
Fixed key press behavior when battery saver display timeout is active.
Fixed issue where a specific sequence could result in double swiping on timer loop pages.
Fixed high power consumption on the map page after loading a course.
Fixed battery saver estimate accuracy.
Fixed showing the battery was charging when the temperature range was exceeded, and battery was not in a charging state.
Fixed layout on the segment/climb dual approach prompt.
Fixed multiple issues with graphical data fields.
Added highlight to the selected data field.
Fixed font size for large data fields.
Added real-time settings menu for voice prompt settings.
Fixed display of unpaved data in course summary.
Fixed activity profile odometer not refreshing after a ride.
Edge 1050 version 10.19 Empty Re: Edge 1050 version 10.19
Message par Monique Mar 1 Oct 2024 - 9:47
version 10.19 disponible
