Update GPS GARMIN 62
+4
popej
Goupil30
8 participants
Page 1 sur 2
Page 1 sur 2 • 1, 2
Changes made from version 2.40 to 2.50: ....... Est ce que c'est plus clair ??
* Added Automatic Shaded Relief option.
* Added display color to track gpx files
* Added import indicator for gpx files
* Added multicaching support
* Added periodic track archiving
* Added track review page improvements
* Improved map selection. Visit [Vous devez être inscrit et connecté pour voir ce lien] for more information.
* Improved keyboard responsiveness
* Fixed issues with inconsistent altimeter readings
* Fixed calendar to display all geocache finds and attempts on the correct day
* Fixed occasional shutdowns
* Fixed paging after logging a geocache
* Fixed shutdown on About Page
* Fixed spot sounding display on certain maps
* Updated map review of tracks and routes. The distance shown is now the distance along the route or track.
Changes made from version 2.30 to 2.40:
* Improved display of position formats on keyboard page.
* Fixed problem with position entry when using Latvian TM position format.
* Removed occasional screen glitch when routes are being calculated.
* Added Spanner interface option to 62 models.
Changes made from version 2.10 to 2.30:
* Added Geocache Filtering
* Added brightness adjustments for BirdsEye imagery
* Improved WAAS performance
* Fixed intermittent issue with two keyboard input bars appearing on spell search
System requirements
1. IBM-compatible PC running Windows XP or later operating system and an available USB port.
System requirements
Goupil30- 4 sat
Un de fichiers de la mise à jour est corrompu !!!!!!!!
Goupil30- 4 sat
Goupil30- 4 sat
Re: Update GPS GARMIN 62
Goupil,
Comme déjà indiqué par Oooops!, autant mettre les infos concernant le détail de la mise à jour en anglais plutôt que mettre ce galimatias sorti d'un traducteur automatique
maj 2.50
ce fichier corrompu bloque t il la maj ?
comment as tu détécté cette anomalie ? comment se manifeste t elle ?
Car via webupdater je n'ai pas eu de pb pour faire cette maj, l'appareil avait bien redémarré et j'ai bien la version 2.50 d'indiquée sur le gps
mystère donc ?
olivie
mystère donc ?
olivie
Exactement le même message ce matin..........
Le Gps est en mode navigation normale pas en mode stockage ?
Goupil30- 4 sat
Je viens d'essayer une mise à jour à l'aide de mon pc portable, j'ai installé webuptader et ai lancé une demande de maj.
La recherche de périphérique s'est bien passée, identification du gps ok.
j'ai accepté les conditions..... et ai coché la case qui va bien
suivant..........
Idem, même message "un des fichiers de maj est corrompu"
et fin de la mise à jour sans pouvoir passer à la v 2.50
ZUUUUUUT GARMIN REZZZZZZZZUT GARMIN
suivant..........
Goupil30- 4 sat
As tu essayé l'anglais (dans ton GPS)?
C'était le cas dernièrement sur des Oregon. Problème d'encodage (accents etc..) de caractères...
Après une petite rectification, tout est à nouveau rentré dans l'ordre.
A voir...
A voir...
tu veux dire que je met mon gps en anglais et que je fais la maj ??
Goupil30- 4 sat
Goupil30 a écrit:tu veux dire que je met mon gps en anglais et que je fais la maj ??
Yes!
C'était le cas sur une mise à jour Oregon
Quand les gens réglaient leur GPS en anglais plus de Bug!
Ils ont rectifiés le tir depuis chez GARMIN...
A moins que cela ne soit un problème de versions Windows américain, français...
Il y a quelques différences parait il. Si le programmeur GARMIN n'en a pas tenu compte, cela suffit.
Cela me rappelle un problème au boulot ou le programmeur et ses collègues ont faillit perdre leur latin!
ok peut être, mais je ne pige pas pquoi un gars est parvenu à faire sa maj !!!
j'ai appelé le gars qui me l'a vendu, il m'a dit que cela venait de chez garmin car j'ai essayé de faire la maj avec un autre pc sous viste et j'ai eu le même buggggggg, RRRRRRRRrrrrrrrrrrrraaaaaaaaaa
Goupil30- 4 sat
J'ai le Gps en britche et pareil bug immédiat dès après avoir coché la case qui va bien et cliqué sur suivant; c'est immédiat, rejet.Goupil30 a écrit:ok peut être, mais je ne pige pas pquoi un gars est parvenu à faire sa maj !!!
RRRRRRRRrrrrrrraaaaaaaaaaaa
Goupil30- 4 sat
Ce qui fout le plus les boules, c'est que Garmin donne un num de téléphone ici [Vous devez être inscrit et connecté pour voir ce lien] et que tu as une charmante voix métallique qui te dit que le numéro n'est pas joignable.Goupil30 a écrit:J'ai le Gps en britche et pareil bug immédiat dès après avoir coché la case qui va bien et cliqué sur suivant; c'est immédiat, rejet.Goupil30 a écrit:ok peut être, mais je ne pige pas pquoi un gars est parvenu à faire sa maj !!!
Et demain à la première heure, je pars 1 semaine en rando dans les gorges du Tarn sans asdl...... Re RRRRRRRRRrrrrrrr.........
Goupil30- 4 sat
PopeJ
J'ai fait pil poil ce que tu viens de me proposer (voir dans quel dossier je l'ai mis, c'est bon ???),
redémarré le gps usb raccordé, j'ai sélectionné de ne pas démarrer en stockage et il a démarré complètement sans faire de maj, pas très normal tout ça non ????
A plus voir dossiers du gps ici => [Vous devez être inscrit et connecté pour voir ce lien]
Merci qd même de tenter de me dépanner, mais t'es certain de ton coup, je ne veux pas faire de conne.... je pars 1 semaine dans les gorges du tarn et la maj du gps n'est pas vitale, même en 2.4 il marche pas mal.
Goupil30- 4 sat
Sur ton image le fichier est GUPDATE.GCD.gcd , devrait être GUPDATE.GCD .
Dossier est bon. Je ne suis pas sûr de l'utilisation USB lors de la mise à jour. Cela est impossible sur mon Dakota mais peut-être fonctionne pour 62.
popej- 4 sat
bonsoir Goupil30,
En général Popej a la solution...
Je crois que ton fichier s'appelle "GUPDATE.GCD.gcd"... si tu enlèves ".GCD" cela ira peut être mieux.
Sinon, je puis me permettre un avis,...Signale le problème par courriel au support et pars dans les gorges du Tarn avec la 2.4..."Patience et longueur de temps font plus que force et que rage".
JL
JL
jld63- 4 sat
Sorry...
mon message est sans objet, Popej est intervenu pendant que j'écrivais...
JL
JL
jld63- 4 sat
Ohhhhhhhhhhhh LE BOULET GUPDATE.GCD.gcd
Mise à jour, passage à la 2.5 en 20 secondes montre en main
CHAMPION POPEJ, en majuscule SVP
Un grand merci au POLONAIS et à ce forum
Les caches des gorges du Tarn n'ont qu'à bien se tenir.
Biiiiiiiiiiiiiiiiiiiiises à toutes/tous
J'ajoute que la Maj a été effectuée le Gps raccordé en Usb, hors alim par les accus, mais 20 secondes, c'est réel, je ne bluffe pas.
En fait, hors du lien que tu m'as donné, par quel chemin y accèdes tu par le site Garmin ??
Goupil30- 4 sat
Hello Goupil,
WebUpdater pour la mise à jour 2.6 de ton G62
OK chez moi
OK chez moi
J'ai contourné le blème en opérant comme m'y avait invité Popej le 10 septembre dernier, j'ai DL le fichier [Vous devez être inscrit et connecté pour voir ce lien] l'ai renommé en GUPDATE.GCD, copié dans le dossier GARMIN, arrêté et redémarré le Gps et effectué la MAJ.
Je suis bien passé manuellement à la V 2.60.
En tout cas merci à ce forum pour toutes ses aides et merci à Quiquinou de m'avoir alerté bien que cette MAJ ne soit pas à mes yeux vitale, je préfèrerai la visionneuse qui m'a fait louper des caches la semaine dernière dans les Gges du Tarn.
Byeeeeeeeeeeee
Byeeeeeeeeeeee
Goupil30- 4 sat
Page 1 sur 2 • 1, 2
» souci Garmin Lifetime Updater
» This Garmin is not eligible for this update ....
» Garmin 276c no update
» Garmin Core Update Service
» (RESOLU)Impossible de télécharger Garmin Map Update
Page 1 sur 2
